Old May 29, 2009 | 10:05 AM
James1549
Default Re: Wiring for Angel Eyes
Andy,
After looking over my directions I need to make one correction. You need to hook up the angel eyes to an "ignition" circuit under the hood. That shouldn't be a problem with the electric box mounted under the hood. If you don't use an "ignition" power source, they will remain on all the time. Sorry about that.
You can connect both sets to the same "ignition" circuit, just have one set bypass the relay to get the effect you are after. Be sure you have them properly fused for protection.
James
