Old May 29, 2009 | 07:11 PM
onehundred80
Default Re: Name of Original battery???
[quote=Sandgrounder]I replaced mine yesterday,the old one was a Mopar PRO 6, built in 05, id 48-4800-8.Replacement is a Canadin Tire 4800 serries,same battery fits in todays 1/2 ton Chev. paid $110 CAD, PLUS TAX AND CORE. Its a perfect fit and has the same vents comming off the side. 3 year free exchange plus 6 years limited warrentywas quoted $260 cad @ dealership[/quote
Sandgrounder, I asked at Crappy Tire if they had a battery that fit the Xfire and I was told that they did not have one. I suppose he looked in the computer and it was blank, I did not bother to pursue it as I could see that I was dealing with a chump.
I wrote the thread on OEM battery replacement and I wanted to add a Can Tire battery if possible.
Could you answer a few questions so that I can add it to the thread?
It is the same size length x width x height Yes or No?
Does it require a spacer under the clamp?
Cold Cranking Amps (CCA) ?
Cat # ?
Thanks
