Let the jack down slowly, and the spring will just dangle in the control arm. It is safe to push the lower control arm down to remove the shock and spring at this point. I recommend removing the spring pad as well and putting it on the eibach springs, locked into the correct position.
the black plastic shield needs to be removed from the stock shock. I put the metal part of the dust shield in a vice and pulled and the shield popped right off. The original bump stop must be removed, trimmed 20mm (2cm) and reinstalled onto the konis all of the original shock bushings are reused. With the konis, a plastic washer, new sleeve, new nut, lockwasher and washer are included. The metal part of the dust shield needs to be drilled to 12mm in order to accpet the koni's larger shaft.
reassemble, rinse (brooklyner weissbeir was my choice) and repeat.
