Old Jun 2, 2009 | 02:14 AM
ckovach's Avatar
ckovach
Default Re: Little help? Has anyone removed the hub/flange from rear axle?
Originally Posted by huudoo
do u mean the nut flang, if so use a punch and hammer seperate the part that locks the nut down.
see section shaft, rear axle figure 3-410 in the crossfire document section
2006 -crossfire-parts-manual.pdf
https://www.crossfireforum.org/forum...ollection.html
also here
Crossfire Repair Manuals
Thanks but no, not the flange nut...that was easy to remove after prying up the locked edge. I am referring to the part that's held onto the axle by the nut, which is the flange, also known as the wheel hub. It is apparently pressed onto the bearing assembly between it and the wheel carrier (also known as the "knuckle")...
