Old Jun 2, 2009 | 05:32 PM
rcompart's Avatar
rcompart
Default Re: Used Supercharger on a N/A model
Originally Posted by BlueStorm
intercooler is not neccessary for 7 psi. I suggest you read CHuck norris's SUPERCHARGER thread...as I originally sent him the PDF file to start his project from.
you might need the voltage clamp for the maf, and some check valves, as that's what they used on the SK kit.
Oh and one more thing, spend some money on a decent data logging computer if you plan on doing this.. really you can't be guessing at this stuff!
All good words of wisdom but you won't need the check valves if you're managing your fuel correctly. A wastegate on the other hand isn't a bad idea though. Yes, I know thye normally go on the exhaust to manage boost. Not the case here though.
