Old Jun 3, 2009 | 08:46 AM
SNAKEWOLF's Avatar
SNAKEWOLF
Default Re: Borrow/rent transmission dip stick
YOU COULD USE THIS
https://www.crossfireforum.org/forum...your-gift.html
IF YOU CHECK IT BEFORE YOU DRAIN COLD AND ADD BACK THE SAME AMOUNT YOU SHOULD BE OKAY
THAT IS IF YOU HAD NO LEAKS OR PROBLEM WITH FLUID TO BEGIN WITH OTHER WISE DO AS WOODY SAYS
GOOD LUCK OTIS
