Old Jun 6, 2009 | 05:03 PM
  #51 (permalink)
Az4R1's Avatar
Az4R1
Default re: HID Install Lows and Fogs with Pictures
Max or any one else who can provide assistance:
I'm in the middle of my installation of low beams and fog light. Low beams went well, all is good and looks great.
However, on the foglights, I can't get power out of either left or right ballast. I used a test light to make sure I have power and ground just before the ballast, and I do.
I was about to conclude that it's just my luck that both ballast were bad, however, I took the chance and tried one of the 9006 ballast to the H7 power supply and it I get power! I even tried the HID 9006 bulb and it works! I'm totally confused now on why I can get power on the 9006 ballast using the OEM fog light connector. Any ideas? I'm not sure what else I can try at this point.
If you feel like calling, my number is (734) 368-2696.
Thanks!
-Az
I saw no mention of "Bulb Out" indicator guarantee. I use this seller and have had very good luck. Same price?
hid kit xenon conversion H1 H3 H4 H7 H11 9005 9007 9006 - eBay (item 390054147613 end time May-25-09 13:03:20 PDT)
They may not care if you have an indicator bulb on. Contact the seller and if he states he will refund for this error, in writing (eBay Messages), you might be OK.
Max
