Originally Posted by vipr1ab
Mine were in pretty bad shape. I've done this repair on other cars before. I start by wet sanding by hand. The first pass takes the longest since you need to make sure you get through all the damaged plastic. I started with 220 grit, then 400 > 600 > 800 > 1000 > 1500, then finish up with 2000 grit. Once I'm satisfied with the sanding, I get my cordless drill with a sponge buffing pad and make several passes using 3M™ Perfect-It ™ Rubbing Compound.
What grit did you use for wet sanding? Great result pictures btw.
