Sorry, I didn't see this sooner!
I can't imagine what issue you would have to prevent the fog from coming on, but perhaps a mis-match of connector pin length? I mean you can mate the connectors, but the copper isn't touching inside when you do. Mine worked fine-no issues.
All I can think of.
Originally Posted by Az4R1
Max or any one else who can provide assistance:
I'm in the middle of my installation of low beams and fog light. Low beams went well, all is good and looks great.
However, on the foglights, I can't get power out of either left or right ballast. I used a test light to make sure I have power and ground just before the ballast, and I do.
I was about to conclude that it's just my luck that both ballast were bad, however, I took the chance and tried one of the 9006 ballast to the H7 power supply and it I get power! I even tried the HID 9006 bulb and it works! I'm totally confused now on why I can get power on the 9006 ballast using the OEM fog light connector. Any ideas? I'm not sure what else I can try at this point.
If you feel like calling, my number is (734) 368-2696.
Thanks!
-Az
