[QUOTE=CALL911]
Originally Posted by dealer6550
just wonndering whats the widest tires i can fit on my crossfire limited coupe 04'.....on stock wheels? i was thinking in the back 295/30/19 pirelli p zero's in the back and im not shure about the front what would fit beside stock. im trying to go as wide as possible without hurting the tires or anything. thanks in advance...
FYI, I had 295 30 19 Contis on my car and went to Pirelli P zero Rosso. They are quite a bit wider than the Contis of the same size! So much so, that I had to go from 20mm spacers to 12mm spacers so they would not rub! I have aftermarket wheels that are 1/2 in. wider than stock.
It is unlikely that one 295mm tire is wider than another 295mm tire, hench the designation. Although your after-market rims are wider, you might also want to verify the
off-set as it compares to an OEM rim. Therein might be the cause of your 'rubbing' and the need for spacers.
Keep the rubber on the road.
