Old Dec 17, 2004 | 05:20 PM
CyberGreg's Avatar
CyberGreg
Default Re: Quick Help Needed With New Head Unit
Originally Posted by ssssly
Hope this will clear some things up.
What should be done is that the stock left and right channel leads should be cut from the wiring harness and terminated with rca plugs. Then these can be safely plugged into the pre outs on an after market head unit.
I hope i explained this well enough for you to understand. If not let me know and I will try to explain it better.
Doh! Now that's a darn good idea and you can rewire the adapter required to install any aftermarket head unit and not mess up your OEM connection if you ever wanted to return the stock head unit. Now this is something I might do over the weekend... SWEET! thanks
