Re: Cabin air stink problem fixed
The light might not come on but it does recirculate for 30 minutes after your AC is turned on. Keep your fan on high and turn off the AC then switch from recirculate to normal and you will hear a difference in the fan sound, then turn on the AC and do the same and there is no difference in the sound because the recirculation is already engaged and cannot be turned off for 30 minutes minimum.
