Re: So now I jumped into the deep end!!!
Ok so I just finished my first of three phases of my modifications and I cannot wait to go for a spin. I took pictures of the cm-30 pump and super cooler install This is one of the easiest modifications I've ever done thanks DJ (Tighted1). I found a really easy way of mounting the Josh pump to the original bosh brackets. If anyone is interested I'll post picks but basically I used 1 1/2 pipe insulation I had left over from another project. I put the pump in the pipe insulation and pushed everything into the bosh rubber insulator and everything went together smoothly.
While I had the bumper off I decided to pull out the headlights and polish them before installing the HIDs.
Two hours of polishing starting with 220 grit paper and ending with 1500. They turned out really good considering how bad they were.
Anyway it's time to go for a test ride. Phase 2 starts in three weeks when I tow the car up to Eurocharged for the exhaust, headers, injectors and dyno tune.
Cheers and thanks for all the information.
collin
