Old Jun 18, 2009 | 12:18 PM
  #56 (permalink)
ProjectMayhem's Avatar
ProjectMayhem
Default Re: Turbo Crossfire on the Dyno crushes 400hp
Originally Posted by ImportLabSRT
The first pull....the car made a mere 350whp....Jerry and Tony made small corrections last night with fuel and timing and 4 flashes later she made 428whp at 17-18psi of boost. She still has a lot in her, but I need to get off the line better before we add more HP. Torque converter and maybe a small shot of N2O to come soon.
~EDIT~ And as for the power curve, I had to ease into throttle so the car would not down shift. WOT was not reached until 4200-4300rpms. On the street, the power is very usable.
Want to know a trick? switch the transmission to winter mode and it starts from 2nd gear. You can do a full dyno pull from idle up to redline this way. I know its not ideal because thats only like 0-75 mph but it will give you an idea of the low-midrange power. I had the same problem as well only able to go wot till 3300-3500 rpm and its really annoying.
