Old Jun 19, 2009 | 02:09 PM
rcompart's Avatar
rcompart
Default Re: Are my window switched backwards?
This is a really quick fix on the manuals and somewhat more time consuming on the autos but all you have to do is remove the shifter surround panel and using a butterknife or other thin sturdy tool to slip in between the tabs that hold the buttons in. Start on one side and get that tab popped out and then keepign slight pressure on the face of the switch, do the same for the other tab. After it's out, you can jsut slide your finger nail under the middle of the switch where it hinges and pop the cover off. Flip it around, verify taht it's corerct and reinstall. Hope this helps.
