Re: Car in shut down mode UPDATE!!!!
Well...i disconnected both cables probably about for 10mins car almost started but went dead again. Clock shows 12:00. We checked the battery and its charging good. I will disconnect it once again and wait at least 20 min. or more. Also the panic button should work after all is reset even if the car does not start right!!!!. I do have a crankshaft sensor on standby just in case none if this works. wish me luck. I need it to go to work on Monday.
