Old Jun 21, 2009 | 06:52 PM
  #62 (permalink)
suicidedoors.com's Avatar
suicidedoors.com
Default Re: just slammed my srt6 to the ground with bags!
Originally Posted by welder7018
dude your the man ...as im looking at it. it seems that theres a plate welded on the bottom and the top for mounts ...wonder if theres a bolton direction to go with this ... whats the low down on the setup i know i ask to many ?s but im very interested in this type of setup seeing ill have this car for awhile
eric
here is how the setup works.
in the front, there is a bolt in upper bracket "cup" with a thick cap that the bolt goes through along with the airline. you will see that the upper bag plate has a flat spot for shock clearance. on the lower front control arm, a plate is welded in place. its very simple.
the rear is even more simple. the upper cup just slides into the coil pocket. dont worry, it stays there. the lower bracket is just another plate welded to the control arm.
before i wanted to put these brackets on the market, i wanted to make sure that everything was right. after 4 years and 47,000 miles there is not 1 thing i would change about the design. one thing is, you have to run re5 slam specialties bags. they are the perfect size for bagging these cars.
