Old Jun 22, 2009 | 04:12 PM
Roy Mander's Avatar
Roy Mander
Default Re: How and Where to install LED Load Equalizers
You only need load equalizers when you change to leds from ordinary bulbs where there is a load factor, for instance direction indicator lights are 21 watts each and the replacement LED only needs milliwatts, so the effect is they will not flash. hope this helps.
