3" srt-6 cold air intake, 30+whp, clears supercooler, adjustable k&n filter!!!
There are many 3" cold air intakes for sale, but i feel a few important differences make mine one of the better choices. It is a true 3" CAI with durable 4 ply couplers on the t/b and the filter side. These are overkill...much more durable than the cheap rubber ones. All the clamps except for the one at the t/b are t-bolt clamps so they provide excellent torque without tearing into the couplers. All welds are TIG welded by BDJ's Racing. If you look closely in the pics you will notice coilpack clearance is great, and i added an extra 2" to the tube that meets the coupler at the radiator support. This allows for adjustability and perfect fitment with the supercooler, since the added width pushes the air filter forward into the grille. A nipple for PCV is on the underside of the intake, just out of sight. The intake is finished off with a 3" K&N filter that is larger larger than most. K&N sells their filter with a casted rim on the inside of the filter that reduces the size, i have trimed this off completely for more air flow. Keep in mind you might need to trim your grille and remove your horn depending on what heat exchanger you have. I have installed other 3" CAI's and found that none of them fit to my liking, this intake is a result of some of the changes i made to my design. With the 185 pulley it made near 30whp over stock. Price is $225 shipped. Paypal preferred. Thanks for looking.
