Originally Posted by Roy Mander
You only need load equalizers when you change to leds from ordinary bulbs where there is a load factor, for instance direction indicator lights are 21 watts each and the replacement LED only needs milliwatts, so the effect is they will not flash. hope this helps.
Incorrect. With the light load from LED's, the car will think you have a failed bulb and give a "Bulb Out" indicator.
