Re: Mandrus Milleniums
Thanks for the quick response.
One note, I wasn't planning on using a spacer. I'm hoping you weren't concluding that from the two offsets I mentioned, that's the offset the guy at Direct Tire suggested to me for a direct fit on the Crossfire, and I know another member here installed the same wheels with that offset and it worked out okay. I hope they were correct.
What offset are your Milleniums, F/R?
The lug bolts are a surprise. I'll do a search now. By the sound of it, if I am not going to use a spacer, I will need to purchase shorter wheel lugs. By how much you think, 0.5", 0.25"?
I need to open the install kit I bought from Direct Tire, it was $70, and it better not be Lug nuts, otherwise they're getting some return mail.
By the way, the rims looked as good as I hoped on your ride.
