Originally Posted by MisterTaz
Also I don't believe your stock lug bolts will work either way. Most aftermarket wheels use a ball shaped head and our stock wheels lug bolts have a cone shaped head. Another thing to watch out for is the rear lug bolts must not stick into the hub assembly any further than the stock bolts or you will damage the parking brakes (inside the rear rotor).
I definately had 35mm offset winter wheels and it cause a major issue on my '07 Base Coupe. I broke the retainer springs on both sides of the rear. It made a major noise issue and did not make me feel very safe. Luckily, I was under warranty and got the dealership to replace them...but it did cost me a couple days rental...
Heed MisterTaz' warning...
Like the old saying goes... measure twice, cut once.
Or in this case: measure twice, mount once.
But now I have the SRT and won't make that mistake again.
