Old Jun 24, 2009 | 05:35 PM
waldig's Avatar
waldig
Talking Re: intake... just need some questions answered.
I do not have a lot of faith in teflon coated intakes even though many do. THe coating has little to no effect on the air friction as the boundry layer of air (film layer ) does not move much and the air flow glides over it. The coating may do more to fill in pits like on a golf ball that cause turbulance and drag limiting flow. In this case paint would improve the numbers but that is not my deal one way or another.
I take exception with the BAD side of teflon. It was developed by accident and helped produce the big bomb.
It does not degrade in the intake manifold as there is no part of the manifold that ever sees 260 degrees centigrad and never will. THere will be no breakdown due to heat in the car even when heat soaking after a run. The bad rap is not deserved in my opinion and I wanted to come out to say so.
Iam doing some radical changes to the intake manifolds to increase flow by some 40%, which is my bet with Rob that I can do it. Tomorrow I will try for the NINTH time to get on a dyno per the schedule as I keep getting bumped for a wild list of reasons. My changes will have NO teflon and I see no reason for it, but the dyno numbers on my tenth dyno run will be posted for all to see.
Teflon is used in MANY medical applicances and non medical machines because of its STABILITY and temperature capabilities and I feel that it should be reviewed in the light of data. Included is the first listing of characteristics I pulled up for the crew to read about, it.
BTW if the teflon peels it will do nothing as the rotors of our superchargers have it on their working surfaces as sealing surfaces. It is not going to do anything to the rings or valves either, it is a lubricant in many ways as a solid and paste.
My $1.38 worth of comment, Ill go back to my non stick kitchen now. Oh yeah 260 c is about 500.00 degrees F...........
Did you know -40C is also -40F??????????That is where you old house R22 freon boils at sea level...
Woody
You can support Wikipedia by making a tax-deductible donation.
if (wgNotice != '') document.writeln(wgNotice);
Polytetrafluoroethylene
From Wikipedia, the free encyclopedia
(Redirected from Teflon)
Jump to: navigation, search
"Teflon" redirects here. For other uses, see Teflon (disambiguation).
PolytetrafluoroethyleneIUPAC name
[show]
Poly(tetrafluoroethene)
Systematic namePoly(tetrafluoroethylene)Other namesTeflon, Syncolon, PolytetrafluoroetheneIdentifiersAbbreviationsPTFECAS number[9002-84-0]PropertiesMolecular formulaCnF2n+2Density2200 kg/m3Melting point327 °C
Supplementary data pageStructure and
properties
n, εr, etc.Thermodynamic
data
Phase behaviour
Solid, liquid, gasSpectral dataUV, IR, NMR, MSExcept where noted otherwise, data are given for
materials in their
standard state
(at 25 °C, 100 kPa)
Infobox referencesIn chemistry, polytetrafluoroethylene (PTFE) is a synthetic fluoropolymer of tetrafluoroethylene which finds numerous applications. PTFE is most well known by the DuPont brand name Teflon.
PTFE is a fluorocarbon solid, as it is a high molecular weight compound consisting wholly of carbon and fluorine. Neither water and water-containing substances nor oil and oil-containing substances are wet by PTFE, as fluorocarbons demonstrate mitigated London dispersion forces due to the high electronegativity of fluorine.
PTFE is used as a non-stick coating for pans and other cookware. It is very non-reactive, partly because of the strength of carbon–fluorine bonds, and so it is often used in containers and pipework for reactive and corrosive chemicals. Where used as a lubricant, PTFE reduces friction, wear and energy consumption of machinery.
Contents
[hide]
[edit] History
PTFE was accidentally invented by Roy Plunkett of Kinetic Chemicals in 1938. While Plunkett was attempting to make a new CFC refrigerant, the perfluorethylene polymerized in its pressurized storage container, with the iron from the inside of the container acting as a catalyst. Kinetic Chemicals patented it in 1941[1] and registered the Teflon trademark in 1945.[2][3]
By 1950, DuPont had acquired interest in Kinetic Chemicals and was producing over a million pounds (450 tons) of Teflon per year in Parkersburg, West Virginia. In 1954, French engineer Marc Grégoire created the first pan coated with Teflon non-stick resin under the brandname of Tefal after his wife urged him to try the material he had been using on fishing tackle on her cooking pans.[4] In the United States, Kansas City, Missouri resident Marion A. Trozzolo, who had been using the substance on scientific utensils, marketed the first frying pan, "The Happy Pan," in 1961.[5]
An early advanced use was in the Manhattan Project as a material to coat valves and seals in the pipes holding highly reactive uranium hexafluoride in the vast uranium enrichment plant at Oak Ridge, Tennessee, when it was known as K-25.
[edit] Properties
PTFE is often used to coat non-stick frying pans as it is hydrophobic and possesses fairly high heat resistance.
PTFE is a white solid at room temperature, with a density of about 2.2 g/cm³. According to DuPont its melting point is 327 °C (620.6 °F), but its properties degrade above 260 °C (500 °F).[6] PTFE gains its properties from the aggregate effect of carbon-fluorine bonds, as do all fluorocarbons.
The coefficient of friction of plastics is usually measured against polished steel.[7] PTFE's coefficient of friction is 0.1 or less[6], which is the second lowest of any known solid material (diamond-like carbon being the first). PTFE's resistance to van der Waals forces means that it is the only known surface to which a gecko cannot stick[8], though it can still use the hairs on its feet like a spider to climb.
PTFE has excellent dielectric properties. This is especially true at high radio frequencies, making it suitable for use as an insulator in cables and connector assemblies and as a material for printed circuit boards used at microwave frequencies. Combined with its high melting temperature, this makes it the material of choice as a high-performance substitute for the weaker and lower melting point polyethylene that is commonly used in low-cost applications. Its extremely high bulk resistivity makes it an ideal material for fabricating long life electrets, useful devices that are the electrostatic analogues of magnets.
Because of its chemical inertness, PTFE cannot be cross-linked like an elastomer. Therefore it has no "memory," and is subject to creep, also known as "cold flow" and "compression set". A little bit of creep allows PTFE seals to conform to mating surfaces better than most other plastic seals. Too much creep, however, and the seal can be compromised. Compounding fillers control unwanted creep and improve wear, friction, and other properties. Sometimes metal springs apply continuous force to PTFE seals to give good contact, while permitting some creep.
Due to its low friction, it is used for applications where sliding action of parts is needed: bearings, bushings, gears, slide plates, etc. In these applications it performs significantly better than nylon and acetal; it is comparable to ultra high-molecular weight polyethylene (UHMWPE), although UHMWPE is more resistant to wear than Teflon. For these applications, versions of teflon with mineral oil or molybdenum disulfide embedded as additional lubricants in its matrix are being manufactured.
Gore-Tex is a material incorporating fluoropolymer membrane with micropores. The roof of the Hubert H. Humphrey Metrodome in Minneapolis is one of the largest applications of Teflon PTFE coatings on Earth, using 20 acres (81,000 m2) of the material in a double-layered, white dome, made with PTFE-coated fiberglass, that gives the stadium its distinctive appearance. The Millennium Dome in London is also substantially made of PTFE.
Powdered PTFE is used in pyrotechnic compositions as oxidizer together with powdered metals such as aluminium and magnesium. Upon ignition these mixtures form carbonaceous soot and the corresponding metal fluoride and release large amounts of heat. Hence they are used as infrared decoy flares and igniters for solid-fuel rocket propellants.[9]
PTFE is also used in body piercings, such as a sub-clavicle piercing, due to its flexibility and bio-compatibility.
In optical radiometry, sheets made from PTFE are used as measuring heads in spectroradiometers and broadband radiometers (e.g. illuminance meters and UV radiometers) due to its capability to diffuse a transmitting light nearly perfectly. Moreover, optical properties of PTFE stay constant over a wide range of wavelengths, from UV up to near infrared. In this region, the relation of its regular transmittance to diffuse transmittance is negligibly small so light transmitted through a diffuser (PTFE sheet) radiates like Lambert's cosine law. Thus, PTFE enables cosinusoidal angular response for a detector measuring the power of optical radiation at a surface, e.g., in solar irradiance measurements.
PTFE is also used to coat certain types of hardened, armor-piercing bullet, so as to reduce the amount of wear on the firearm's rifling. These are often referred to as "cop-killer" bullets by virtue of PTFE's supposed ability to ease a bullet's passage through body armor. However, this is simply an urban myth as PTFE has no effect in the bullet's ability to penetrate soft body armor, only on the ability to prevent damage to the weapon from firing very hard ammunition.
PTFE's low frictional properties have also been utilized as computer mice feet such as the Logitech G5 and Logitech G7 computer mice series from Logitech or most Razer gaming mice (e.g. the Deathadder, Lachesis). The low friction provided by PTFE allows the mice to be moved and glide across surfaces smoothly and with less effort.
PTFE's high corrosion resistance makes it ideal for laboratory environments as containers, magnetic stirrers and tubing for highly corrosive chemicals such as hydrofluoric acid, which will dissolve glass containers.
PTFE can be used as a thread seal tape in plumbing applications.
PTFE grafts can be used to bypass stenotic arteries in peripheral vascular disease, if a suitable autologous vein graft is not available.
PTFE can be used to prevent insects climbing up surfaces painted with the material. PTFE is so slippery that insects cannot get a grip and tend to fall off. For example PTFE is used to prevent ants climbing out of formicaria.
[edit] Safety
The pyrolysis of PTFE is detectable at 200 °C (392 °F), and it evolves several fluorocarbon gases and a sublimate. Animal studies indicate that it is highly unlikely that these products would be generated in amounts significant to health at temperatures below 250 °C (482 °F).[10] While PTFE is stable and non-toxic, it begins to deteriorate after the temperature of cookware reaches about 260 °C (500 °F), and decompose above 350 °C (660 °F).[11] These degradation products can be lethal to birds, and can cause flu-like symptoms in humans.[11]
Cooking fats, oils, and butter will begin to scorch and smoke at about 200 °C (392 °F), and meat is usually fried between 200–230 °C (400–450 °F), but empty cookware can exceed this temperature if left unattended on a hot burner.
A 1959 study (conducted before the U.S. Food and Drug Administration approved the material for use in food processing equipment) showed that the toxicity of fumes given off by the coated pan on dry heating was less than that of fumes given off by ordinary cooking oils.[12]
[edit] Carcinogens in production
The United States Environmental Protection Agency's scientific advisory board found in 2005 that perfluorooctanoic acid (PFOA), a chemical compound used to make Teflon, is a "likely carcinogen." This finding was part of a draft report that has yet to be made final.[13] DuPont settled for $300 million in a 2004 lawsuit filed by residents near its manufacturing plant in Ohio and West Virginia based on groundwater pollution from this chemical. Currently this chemical is not regulated by the EPA.
In January 2006, DuPont, the only company that manufactures PFOA in the US, agreed to eliminate releases of the chemical from its manufacturing plants by 2015,[14] but did not commit to completely phasing out its use of the chemical. This agreement is said to apply to not only PTFE used in cookware but also other products such as food packaging, clothing, and carpeting. DuPont also stated that it cannot produce PTFE without the use of the chemical PFOA, although it is looking for a substitute.
PFOA is used only during the manufacture of the product—only a trace amount of PFOA remains after the curing process. DuPont maintains that there should be no measurable amount of PFOA on a finished pan, provided that it has been properly cured.[15] A 2005 U.S. Food and Drug Administration (FDA) study detected PFOA in finished PTFE products including PTFE/Teflon cookware.[16] A February 2007 New York State Department of Health study detected PFOA in the gas phase coming from new nonstick cookware and microwave popcorn bags;[17] this research was funded by a 2005–2006 $17,700 grant from the Consumers Union.[18]
As of August 2008, the EPA's position was that it "has no information that routine use of household or other products using fluoropolymers, such as non-stick cookware or all weather clothing, poses a concern."[19]
[edit] Similar polymers
Teflon is also used as the trade name for a polymer with similar properties, perfluoroalkoxy polymer resin (PFA).
Other polymers with similar composition are also known by the Teflon name:They retain the useful properties of PTFE of low friction and non-reactivity, but are more easily formable. FEP is softer than PTFE and melts at 260 °C; it is highly transparent and resistant to sunlight.[20]
[edit] See also
[edit] Footnotes
  1. [*]
[edit] References
  • Ellis, D.A.; Mabury, S.A.; Martin, J.W.; Muir, D.C.G. (2001). "Thermolysis of fluoropolymers as a potential source of halogenated organic acids in the environment". Nature 412 (6844): 321–324. doi:10.1038/35085548.
[edit] External links
[show]
v d e
Health issues of plastics and Polyhalogenated compounds (PHC)'sPlasticizers: PhthalatesDIBP · DBP · BBP aka BBzP · DEHP aka DOP · DIDP · DINP · DIDP
Other plasticizersOrganophosphates · Adipate-based (DEHA · DOA)
MonomersBisphenol A (in Polycarbonates) · Vinyl chloride (in PVC)
Other additives incl. PHC'sPBDEs · PCBs · Organotins · PFCs
Health issuesTeratogen · Carcinogen · Endocrine disruptor · Diabetes · Obesity
MiscellaneousPVC · Plastic recycling · Plastic bottle · Vinyl chloride · Dioxins · Polystyrene · Styrofoam · PTFE (Teflon) · California Proposition 65 (1986) · List of environmental health hazards · Persistent organic pollutant · European REACH regulation (2006) · Japan Toxic Substances Law · Toxic Substances Control Act
[show]
v d e
E.I. du Pont de Nemours and Company (DuPont)Corporate Directors:Samuel Bodman · Richard H. Brown · Robert A. Brown · Bertrand P. Collomb · Curtis J. Crawford · Alexander M. Cutler · There du Pont · John T. Dillon · Marillyn Hewson · Charles O. Holliday · Lois Juliber · Ellen J. Kullman · William K. Reilly
Products:Corian · FE-13 · Hypalon · Kalrez · Kapton · Kevlar · Mylar · Neoprene · Nomex · Nylon · Sorona · Teflon · Tyvek · Zodiaq · Zytel
Subsidiaries and joint ventures:Pioneer Hi-Bred · Solae · DuPont Danisco
Divisions and facilities:DuPont Building · DuPont Central Research · DuPont Experimental Station
Notable people:Eleuthère Irénée du Pont · Alfred I. du Pont · Eugene du Pont · Francis Gurney du Pont · Francis Irénée du Pont · Lammot du Pont · Pierre S. du Pont · Donaldson Brown · Wallace Carothers · Uma Chowdhry · Thomas M. Connelly · Linda Fisher · Steven Ittel · Stephanie Kwolek · Rudolph Pariser · George Parshall · Roy J. Plunkett · John J. Raskob · Irving S. Shapiro · Joseph Shivers · Howard Ensign Simmons, Jr. · Charles Stine · Nathaniel C. Wyeth
HistoryEleutherian Mills · E. I du Pont de Nemours Company · Hercules Powder Company · Atlas Chemical Industries · B Reactor (Manhattan Project) · Remington Arms · Savannah River Site · Kinetic Chemicals · Conoco Inc. · Consolidation Coal Company
Annual Revenue: $27.3 billion USD (1.3% FY 2004) · Employees: 60,000 ·
Stock Symbol: Preferred stock: NYSE: DDPRA, NYSE: DDPRB Common stock: NYSE: DD · Website: www.dupont.com[show]
v d e
PlasticsCross-linked polyethylene (PEX or XLPE) · Polyethylene (PE) · Polyethylene terephthalate (PET or PETE) · Polyphenyl ether (PPE) · Polyvinyl chloride (PVC) · Polyvinylidene chloride (PVDC) · Polylactic acid (PLA) · Polypropylene (PP) · Polybutylene (PB) · Polybutylene terephthalate (PBT) · Polyamide (PA) · Polyimide (PI) · Polycarbonate (PC) · Polytetrafluoroethylene (PTFE) · Polystyrene (PS) · Polyurethane (PU) · Polyester (PEs) · Acrylonitrile butadiene styrene (ABS) · Polymethyl methacrylate (PMMA) · Polyoxymethylene (POM) · Polysulfone (PES) · Styrene-acrylonitrile (SAN) · Ethylene vinyl acetate (EVA)) · Styrene maleic anhydride (SMA)
Retrieved from "http://en.wikipedia.org/wiki/Polytetrafluoroethylene"
Categories: Fluorocarbons | Plastics | Fluoropolymers | Dry lubricants | DuPont | Dielectrics | Pyrotechnic oxidizers | DuPont products
Views
Personal tools
if (window.isMSIE55) fixalpha(); Navigation
Search
Interaction
Toolbox
Languages
if (window.runOnloadHook) runOnloadHook();
