Old Jun 25, 2009 | 11:33 PM
ProjectMayhem's Avatar
ProjectMayhem
Default Re: higher temps issue
does the Heat exchanger block the entire radiator? also is there any space between the HE and Radiator? if they up agaist each other it could be restricting airflow, ideally you would like to beable to stick two fingers inbetween them. You could always try adjusting the fan triggers so your not getting so ht while at idle.
