Old Jun 26, 2009 | 12:57 AM
ZAHANMA's Avatar
ZAHANMA
Default Re: higher temps issue
Originally Posted by ProjectMayhem
does the Heat exchanger block the entire radiator? also is there any space between the HE and Radiator? if they up agaist each other it could be restricting airflow, ideally you would like to beable to stick two fingers inbetween them. You could always try adjusting the fan triggers so your not getting so ht while at idle.
exactly what i was thinking...
or...did you route your coolant overflow to your supercooler instead of leaving it hooked up to your radiator.
There is enough volume in the supercooler to not need more overflow than is in the hoses, but the radiator volume probably lends itself to needing the stock overflow tank to help circulate more... just a thought.
