Originally Posted by mikep330
I looked under the car and saw the bottom of the fornt bumper scraped up and I torqued the lug nuts to 81ft lbs. I did have the car on jack stands for couple of days and it was about a foot of the ground. I wonder if some settings were thrown off?
I assume when you say settings you are talking about caster, camber, toe in ??? If you placed the jack stands in the proper place, ie not on the tie rod ! Your settings are probably fine.
Did you backtrack your brake job.........?
