Old Jun 26, 2009 | 10:14 AM
Bulldogger's Avatar
Bulldogger
Default Re: higher temps issue
Originally Posted by ProjectMayhem
does the Heat exchanger block the entire radiator? also is there any space between the HE and Radiator? if they up agaist each other it could be restricting airflow, ideally you would like to beable to stick two fingers inbetween them. You could always try adjusting the fan triggers so your not getting so ht while at idle.
How would you go about adjusting the fan triggers???
