Thread: amp connector
Old Jun 26, 2009 | 10:46 PM
onehundred80
Default Re: amp connector
Originally Posted by typhoon55
Once the wires are inserted into the plastic connector from the factory, are they designed to be permanent so as never to be removeable?
It sounds like the barb is very difficult to release once in place.
I am thinking of making a modified connection for the 2 wires so i do not have to replace the entire connector. Just not sure how ...
You could look for two terminals that fit the amp socket, solder them to the wires, insulate them and cut off the section of plug with the damaged terminals. They would fit the amplifier without the damaged connector getting in the way.
