Old Jun 27, 2009 | 02:31 PM
mikep330's Avatar
mikep330
Default Re: Help Somethings Scraping!!!
Originally Posted by Stogey
I assume when you say settings you are talking about caster, camber, toe in ??? If you placed the jack stands in the proper place, ie not on the tie rod ! Your settings are probably fine.
Did you backtrack your brake job.........?
I did backtrack and i put the jack stand in the proper place under the doors but to lift the car i put the jack behind the proper place until the car was high enough for the stands. I also have vibrations in the steering wheel at 55-60 mph. I think my balance is off. after i get that done i hope that will fix the problems. i can post some pics if it would help? thanks for your help
