Old Jun 29, 2009 | 09:35 PM
andrew's Avatar
andrew
-C-I-C-C-I Associate Member
Default Re: major creaking/noises in the drivers door panel...ne1 else?
~ update for others in need...
the dealer would replace the panels under warranty to eliminate the creaks but the kept coming back every 12k or so.
but if one is out of warranty (most are) - i removed the panel and add some padded foam tape to the plastic contact points to aid with the noise.
Single Sided Low Density PVC Foam Tape on Tapes & Technical Solutions LLC
cheers,
andrew
