Old Dec 27, 2004 | 10:35 AM
NJspeed69's Avatar
NJspeed69
Default Re: Car stalls on hill
Alvin, thats exactly what I'm saying. Since I experienced the same thing with the wing, as have others, and the radio always says "chrylser" when you turn it on or off, theres one main theme causing the stall, and thus the other problems. It might be solved just by adding that "Dry Gas" or whatever stuff you want to use that gets water out of the tank. You might have to full up, add a can of dry gas, and then drive until the tank is on empty, but this is what I'd do. Or like Alvin said you could just drain the fuel tank.
