Old Dec 28, 2004 | 10:56 PM
CyberGreg's Avatar
CyberGreg
Default Re: Problems w/Aftermarket Radio -- No Sound
Originally Posted by prb4t
Hi All,
I purchased an Alpine CDA-9825 receiver with the KCA-420i (to control my ipod) for my '04 Coupe. I ordered it all through Crutchfield and got the following installation parts :
Euro Antenna Adapator
VW wiring harness
Universal DIN Tool
I wired it all up and it powers on OK. But I get no sound from the system. I called crutchfield and they said I had to run separate wiring to each speaker and that no sound would go through an aftermarket head through the infiniti amp.
Did anyone else have this problem? Or better yet, a solution?
Thanks
Sounds like you missed the AMP turn on like I did. Once I connected it all was well. Make sure you switch the yellow and red wires on the VW connector.
As for the speakers, only the front ones are wired in the Crossfire (white and gray on the VW harness I think) and if you look at the Crossfire radio harness, the rear speaker wires are missing.
Post back if you still need help.
