Old Dec 29, 2004 | 04:40 AM
HDDP's Avatar
HDDP
Default Re: Custom Strut Bar Tower & Sway Bar Kit
Here are the blueprints for the strut tower kit. I am having a one-off manufacured as of this posting. I am going to test for fitment when it arrives in a few weeks, and then take the car out to the track to see if it creates any over-steer. If all goes as expected, I should be able to deliver the kits in early spring. I designed it to go exactly across the airbox, directly from each strut tower. The clearance should be perfect so that it won't rub either the inside of the hood or the airbox. And it's designed with a half hexagon cross bar that will give maximum stiffness.
I'm also designing a bit tighter sway bar system for both the front and rear since Eibach and the others have discontinued their kit for the SLK320. I will post when the blueprints are done and it is in manufacturing.
https://www.crossfireforum.org/galle...cat/500/page/1
