dont go to the dealer. you can probably fix it yourself with a 10mm socket and extension.
ive had this problem since day one and finally decided i would take care of it. after reading through the door panel removel
https://www.crossfireforum.org/forum...ead.php?t=3475 (thanks x-fired) i went out this morning, removed the door panel, and looked for the adjustment bolts. stop right there. you dont need to remove the door panel to make the adjustments ::doh::
just remove the water drain pop-ins underneath the door, and remove the metal bracket that is on the door above the door latch (two small torx heads). adjusting these three bolts is all you need. but be careful. if you drop the socket inside the door panel like i did you WILL need to remove the door panel (good thing mine was already off
