Old Jul 2, 2009 | 09:30 PM
KrzyFast's Avatar
KrzyFast
Default Re: Loss of Power Question
Guys,
Zahanma summed it up best when he said "burp it and replace the fuse - No 13 if I remember correctly - it IS a 10amp fuse for sure.
I feel like such a dumba$$. I replaced the pump but never thought to check the fuse - with the SC cutting in and out i just thought the pump was done and not able to keep up. Potentially the pump was okay - obviously worn out since it blew the fuse - but who knows at this point?!?
I plugged in the new fuse and the Johnson kicked right in and I haven't had a problem since....and it has been pretty hot here in Currituck, NC...low to mid 90's.
Unfortunately I do not have a 1/4 mile track close by - Richmond, VA is the closest. I need to get up there and run it, but it is about 2-2.5hrs away. There are two 1/8 mile tracks pretty close by, but I don't know about running 1/8 mile. But then again I guess some track time is better than none.
Thanks again guys! The car is running like a champ!
Cheers,
KrzyFast
