Old Jul 4, 2009 | 02:49 PM
The Beep's Avatar
The Beep
Default Re: roadster rear window stick-up
Primary cause? Top up, windows down. It's called "Cowl Shake" and I learned about this with the C4 Vette. With the Targa top removed and windows up, a resonant or vibrating air pressure would shake the interior to pieces.
I noticed this with the XF right away and will NOT drive even secondary roads with the windows down unless the top is down also.
Having said that, having a heavy glass window simply glued to the top is not the best idea either.
