Old Jul 13, 2009 | 08:07 AM
theglot's Avatar
theglot
Default Re: Changing Engine Coolant
I decided last Fall that it was time to change the coolant in my '04.
Found the special antifreeze at NAPA. Make sure you get the type recommended in your manual. You don't want to mix the different types.
Put it up on a lift, unscrewed the drain plug and let it drain for 30 minutes. Opened up one of hte block drain plugs and drained the block.
Put in the new and am good to go for another 5 years.
(Caution if you do this at home. Antifreeze is extremely toxic to pets)
