Old Jul 14, 2009 | 04:41 AM
eikon's Avatar
eikon
Default Re: Chrome Turn signeal Bulbs not working
I also got ns-fx chrome signal bulbs for both front and rear turn signals. Installing them is a bit tricky, you have to push one pin into the one slot that does not one directly across from it, then twist the other pin into the other slot on the other side and push down. Quite easy once you know the trick, but it took installing all four bulbs before I learned. I too like the "no yolk" look.
