Originally Posted by eikon
I also got ns-fx chrome signal bulbs for both front and rear turn signals. Installing them is a bit tricky, you have to push one pin into the one slot that does not one directly across from it, then twist the other pin into the other slot on the other side and push down. Quite easy once you know the trick, but it took installing all four bulbs before I learned. I too like the "no yolk" look.
The way I see it if it is advertised to be for a crossfire it should fit no problem like an OEM bulb.. Yes I could fit them into the housing but thy did not lock in place cause the locking pins are not in the correct place. I was not happy with their product at all. New ones shipped yesterday from a different company
