Old Jan 3, 2005 | 01:29 AM
HDDP's Avatar
HDDP
Default Custom Sway Bars
I have finished the blueprints for the modified sway bars and will have them manufactured in a week or so.
The specs look like this
OEM Front 26mm
OEM Rear 16mm
NEW Front 29mm
NEW Rear 19mm
Arm length remains the same. The proportional stiffness increase is somewhere in the range of 90% which should still flex enough to not cause any damage to the sub-frame yet eliminate much of the body roll while keeping the neutral steering characteristics designed in from the factory.
I will post details after I road test and then post cost for kits.
