Replacing Map Lights with LEDs
Jul 20, 2009 | 11:35 AM
permalink
itsky
Feb 2008
4,084
Tennessee
Re: Replacing Map Lights with LEDs
Ok, here are step-by step with photos:
1. Using a credit card or medium sized flathead screwdriver, gently pry out the map light cover from the back (away from the windshield)
2. Once the main cover is off, use a T-15 (Torx) screwdriver to remove two screws from the molding. Gently, pry the the plastic mold out using a flat head screw drive. There is a power cord attached on the right side of the molding (you won't see it until you start to take the molding out).
3. Once the power cord is removed, the molding should come right out. You will see the two light bulbs. Gently twist the plastic base of the bulbs and they should come right out. Save these lights just in case your LED lights do not work.
itsky
View Public Profile
Send a private message to itsky
Find all posts by itsky
