Old Jul 20, 2009 | 11:41 AM
itsky's Avatar
itsky
Default Re: Replacing Map Lights with LEDs
4. Insert your new LED lights with the twist lock bases in the same spots where the light bulbs came out.
5. Reconnect the power and test the LEDs to make sure they come on (open your door or hit the switch to turn them on). If they DO NOT light up (polarity mismatch), you may need to take the lights out, turn them 180 degrees and twist them back in place. Test to make sure the LEDs work.
6. Gently put the mold back in place (you should see how the molding will line up with the hole) and test to make sure lights work.
7. Screw back in the two screws you took out.
