Re: A potential nightmare averted… thank you Crossfire Forum! Crankshaft Position Sensor
I think you have used improper terms in your proceedure. I am sure your engine will "turn over" even with a bad cranksensor, it just won't fire the plugs and injectors to let the engine run. Your starter is what "turns the engine over". A defective cranksensor will not allow the engine to run.
James
