Re: Car won't start
If it turns out to be the Relay Control Module, you can buy them cheaper from Mercedes Benz. If you pull the relay module it will more likely than not have a MB part number on it !
Or if you're good with a soldering iron, more than likely a solder joint is broken. Repair and save yourself 170 bucks !
