Old Jul 26, 2009 | 12:15 PM
IMPERIAL4EVER's Avatar
IMPERIAL4EVER
Default Re: Burning rubber smell
Originally Posted by oledoc2u
my bet is a short, shouldn't see smoke anytime...make sure your fog lamps are both working. if one is out, then a wire may have burnt into...if not, you may have something down in that corner rubbing. You will know soon enough, cause this car is full of sensors, once fuse blows, you will see an idiot light for sure.
Thank you. I went out to thr garage while the engine had cooled down and took a flashlight and followed the pattern of all of the belts and all seem to be tight and seated correctly. Tugged on them as well. I then decided to start the car and let it idle for a few moments while using the flashlight hoping to see where the smoke/smell issue is originating from but could not get it to repeat itself. didn't see any dripping oil as well. Valve covers seem tight. Oh well. Maybe it is just a break in issue. Stay tuned.
Foglights both functional.
