Re: Loosing Air
Quote: Thanx sounds like the Goodyear manger is trying to get away with poor mounting. I do loose 5-8 lbs/week (measured on one front and takes about 3 weeks to loose that musch in other front. One rear tire looses 5-8 in 3 weeks in winter. All mounted by same dealer.
Sure sounds like a bad mount job to me. Even that much in 3 weeks is excessive. If those are new tires I would make them deal with it. Depending upon temperature and atmosphoric pressure change it is possible to lose pressure but that sounds excessive in a relatively stable condition. Going from season to season can be a problem but that is not your case. Bead sealer will work.
Thanks, great translation on the pool response. Now I get it.
