Old Jul 27, 2009 | 02:21 AM
shapeshifter309's Avatar
shapeshifter309
Default Re: Brake problem. Need advice?
No heat means it is not working, therefore no noise. Possibly the cylinder is frozen up or a blocked line. If the emerg.brake was frozen it would warm up the rotor as well. Have you thought of a bearing failure?
Dear god I hope it isn't. I doubt that it is, since I would suspect there might be a little more to it then noise. Either way, I don't have the money for expensive repairs right now, so I'm hoping it's what xfirepop described.
I'm setting up an appointment at my local shop tomorrow morning. The guy that runs the place worked a lot on my last car, and he does good work, so I trust him to get the job done right. I think his labor rate is only $70 an hour and most of the time, he charges a flat rate for certain services.
