Old Jul 28, 2009 | 06:54 AM
shapeshifter309's Avatar
shapeshifter309
Default Re: Brake problem. Need advice?
Worn brake pads/rotors are not covered but if the car has a fault in the brake system due to bad parts etc it should be covered for the 3 years, even if you are the second owner.
Worn pads/rotors are covered if their failure was due to something else.
Good point. I'll call the dealership here today and ask them about it. In the warranty info, it says pads and rotors. If the caliper is screwed and has been causing damage, they should replace the rotor and pads too, if they are damaged enough.
Would me being 53 miles over the 24,000 allow them to try to claim it as neglect by me though? since I haven't gotten the recommended brake system flush? And by recommended, I mean the service manual recommends it, not just the dealer I took it to last.
