Old Jul 28, 2009 | 09:46 PM
onehundred80
Default Re: Seat Adjustment Controls
Originally Posted by ronperreault
Door open door closed I know how that works, our problem has nothing to do with that.
To get the switch to work I have to remove it from the trim panel. The internals of the switch wear out prematurely.
I have disassemble the switch and rebuilt it from internals from the passenger seat, which does not use the height adjustment.
I just figured someone else had the issue and found a solution. I have considered rewiring it to use double throw momentary switches if I can find one that are small enough and can handle the amperage.
r
Sorry I spoke. Good luck.
