Re: New Wheels
depending on the offset you could go with a width wider than the factory size but 10 and 13 will push you out past the body panels, the width can only go so far inward due to the obvious ie suspension, i went with 19 by8 in the front and 20 by 9 in therear, you could get a little wider if you order 3piece wheels wich are generally built toyour specs concerning offsets and what have you. you are also lokking at a lot of money for three piece wheels, approx., 4500 and up for the wheels alone
